Eyong
  • Topics: 2
  • Country: turkiye
  • Bike Model: hyosung gv 250 EFI
Hi everybody. 17 number (Thrust Bearing, Release HY -HY 09263H15001) The two directions are different from each other. Does anyone know which point should be attached to which direction?
Bearing is identical on both sides , unless previous owner put the wrong bearing ?
The bearings on both sides are not the same, so I’ll take a close-up photo and upload it. I took a video while disassembling it, and I can see its orientation there.
The inward-facing surface, which fits the shaft, is slightly rounded. The outward-facing surface, which fits the washer, is sharper.
Those who can’t find engine gaskets in their country or region can do the same as I did. You can buy a sheet of klingird casket and carefully cut the gasket yourself.
