Sep 12, 2025 at 7:23 PM
#20761
Usually i wait until the fuel pump is primed then play with the kill switch button 3 times or if the pump doesn’t prime i give the dash a few seconds to sweep up and down, then try again.
Also while at it, double check continuity from the clutch switch down to the ecu connectors and same for the side stand , so you want to be sure the ECU can sense the bypass (thinking the switches are still there, then it will allow you to shift gears)
