Sep 10, 2025 at 10:40 PM
#20733
Would you be comfortable taking the SV motor + electrics + harness ? (Work involved⚠️) then putting it in the frame?
I have not used an SV650 cdi but i suspect the two engines will not have the same cam shaft timings as each other. Or that the cdi expects a hyosung cdi
I suspect if SV worked Hyosung would not need to make their own as they did help make the SV on some parts but to Suzuki’s own requirements
