Viewing 2 reply threads
    • #20731
      Werner
      I have read many threads about CDI replacement with a Suzuki SV 650 ( 1st GEN Carbs 99-02 ). I can confirm pin layout is identical . The Suzuki has throttle position, which the Hyosung can ignore .  I have not read that anyone  had success.  I got this blue cool chromey looking bike sitting here ( Western Canada ) with a shorted CDI. The replacement cost is very unattractive . Many old Suzuki Sv 650 in nearby bone yards.
    • #20733
      Would you be comfortable taking the SV motor + electrics + harness ? (Work involved⚠️) then putting it in the frame?
      I have not used an SV650 cdi but i suspect the two engines will not have the same cam shaft timings as each other.  Or that the cdi expects a hyosung cdi
      I suspect if SV worked Hyosung would not need to make their own as they did help make the SV on some parts but to Suzuki’s own requirements
    • #20735
      Werner
      Super thanks, Marcel !!! That may be the reason I did not find success stories on this.  Just got the thing. Not running , of course !!  Figured , I how much can there be wrong with it.  Surely did not want to sink another $600 (CA)into it.  Then , there is the question of durability of this devise. Good thing I got my 650 vstrom. It has never acted up. sofar, anyway.
