Sep 1, 2025 at 6:48 PM
#20639
IAP sensor came in today, before installing, I had disconnected the battery for around 2 days, also charged it. Sprayed contact cleaner on every socket/plug I found. Installed the new IAP, made sure everything is connected. I let the bike idle for a while, around 20-30 minutes. Issue remains, FI still lights up, and code still c18.
Will riding the bike make any difference? The bike will run, but takes quite some cranking to start it up, and eats up the battery, so I may be left stranded. I won’t go far but I do need to go to a gas station to check tyre pressure.
