Aug 27, 2025 at 7:29 PM
#20599
Today I finally received the brake lever I ordered and it is a correct fit for the old one. I did have to force the mounting bolt as the hole in the new lever was slightly out of position. I also put a bit of white grease on the bolt and lever to allow it to operate smoothly.
If someone needs one of these levers, search the part number listed earlier and a couple of sources pop up. I used Hyosung Parts. The shipped quickly. The long delay before I got it was due to Canada Customs processing time.
