LaserBeam
  • Topics: 14
After we solve your battery-drain issue better clean that fuel system. Tip the old petrol out so you can rinse the tank with a little bit of gas & a little bit of fuel Cleaner – swirl it around, coat as much of the inside as you can. Wash out the sludge or rust & tip it out.  Poor Fuel System Cleaner into the Petrol Tank, along with some fresh high octane gas, (95 or 98 Octane) & new Fuel Filter. Can take out spark plugs & spray a bit of carby-cleaner into the combustion chamber. May help loosen sludge on the piston, the cylinder walls & maybe even the valves. Then it burns more easily & heads out the exhaust, or into the oil, where it belongs. Along with a fuel system cleaner, it’s a cheap & easy way to put some life back into the machine. Run the bike stationary at maybe 5000-6000RPM for a few seconds then let it idle & repeat. The more of that Fuel cleaner you ram in there, the better. Don’t let the bike get too hot though. The battery drain must be a park light stuck on or headlight switch or something similar, i guess but i don’t know. Marcel & the guys here should have some ideas.
LiquiMoly: if their FuelSystemCleaner is as good as their engine oil, i want some.
-----LaserBeam---->
