thank you lazer for your help and information and after fixing the fuse issue me and my friend were troubleshooting many different symptoms and we decided to throw starting fluid straight down the intake, and the second we did that the bike came alive. It literally spit out black gunk and liquid straight out of the exhaust onto the wall, staining the house and the thing kicked alive. it revved extremely good. It was a beautiful sight thing sounded extremely healthy (only 1200 miles on the engine)  and even if we turned it off, it would turn right back on with the starter fluid so we decided to call it a day come back tomorrow, take apart the carbs and clean out all the jets and so we did we put everything back to how it was and  made sure all the lines went back into their correct spots and now no matter what we try even the fluid trick it will not back up start no matter what so we’re thinking it’s a spark issue because fuel is going to the carbs and there’s also good compression it cranks all day but will not start so maybe we used the last bit of spark It had left before the ignition coils gave out the only other things that I could think of are the crank shaft sensor being off or the voltage is off somewhere I put in new spark plugs so that can’t be it, what do you guys think? I really don’t wanna quit on it but I’m not the wealthiest person so I only got so much to give. I appreciate any and all help
