Aug 9, 2025 at 6:49 AM
#20446
I’ve got the strong bolts & i did buy nylon lock nuts but they can be a pain to remove. I was thinking about WIRING up the nuts like on race-bikes but it’s a bit time consuming & not quick to remove either. Nylon Lock Nuts it is then. Thank you, Marcel. My bike never had normal washers under it’s normal nuts. When i saw that i freaked out a bit. I fully twist the throttle all the way around and keep it there. I need all this stuff tightened up right so i can survive the ride. 😆
-----LaserBeam---->
