FJ
  • Topics: 2
  • Country: Mauritius
  • Bike Model: Hyosung GT250R
I found the IAP sensor for the rear cylinder/ throttle body.
https://postimg.cc/ThsKVpCd
Then I went to look for the front cylinder so I can swap them. Am I crazy or is the front IAP just MISSING, shouldn’t it be there (circled red in the next picture), just below the intake hose as the other one is?
https://postimg.cc/Wd3YQY06
Basically the bike starts on the front cylinder only, with quite a bit of cranking, then takes around 5 mins of idling for the second cylinder to start working. After 10 mins of idling, both cylinders run and bike will rev to redline in neutral. HOWEVER, under load, in all gears, it barely ever goes above 7k rpm, if it does, it’s erratic and sudden, like it gets stuck and suddenly goes up, inconsistently.
Mechanic fully serviced the bike but this error persisted so he told me to research on forums because this bike doesn’t exist anymore where I live.
The code is C18. So that’s why I wanted to swap the IAPs to see if I can reverse the problem, which would indicate one IAP gone bad. Hence I’d just replace. I cannot find the front IAP and I really hope it’s not missing. Should it be where I circled?
