Aug 4, 2025 at 4:32 PM
#20332
Too much current from that box will fry everything and it will no longer turn on from a battery again. (Too much amps)
So if the starter won’t spin for the battery on its own, get a new one. And try again.
If that fails , we should assume the starter motor is toast. Then at this point, strip rest of the bike until you find the strongest place you found burn smells.
