Aug 2, 2025 at 11:17 AM
#20268
IAP will look like something like this:
https://www.ebay.co.uk/itm/256727468290
It will physically be on the throttle body, and also there will be a TPS (throttle position sensor) on then, so a bunch of wires in your picture seen to burying themselves deep down your intake pipes, it is suggesting there is other sensors you haven’t seen yet but it is a narrow space down there.
It can be easier to carefully remove the throttle bodies but do not forget where each cable goes so you don’t accident put “rear injector” connector to “front injector cable” etc.
Also if you ever remove those bolts (CAREFULLY!) , it is 100% advised to replace the bolts same size with stainless steel and new rubber-orings!
