Hello, I’ve recently bought a GT650R and I need a new wiring harness. I’ve spoken to Marcel about it and he said that I have a discontinued ECU. It has a mitsubishi logo on it. If anyone can help me make or find a harness, that would be amazing!
keep an eye on eBay for one, but other than that it would be easiest to repair. Get yourself an 8×4 foot sheet of ply, mdf or similar. You can then pin the current loom to it, mark all the connectors and then do a continuity test for each wire.
How will I know which loom to get from eBay?
when I bought mine, I checked the ECU plugs to make sure they were the correct type, Â but even then I still had issues as there was slight differences, such as the connector for the dash/lights was wired slightly different (different order in the connector block)
