Jul 19, 2025 at 6:54 PM
#20092
The plug under the seat is a very small 2-pin one.
or Switch Key On/Off 3x quickly and WAIT….
Red light will flash, count the blinks and pauses , it is telling you a code.
Eg…..
10 blinks _pause_ 2 blinks _ pause 1 blink
(Then it repeats the same sequence) ==== This could example mean Injector #1 (Front) is faulty or has issue. with ECU
Sometimes you get
10-2-1
10-5-8
Those 2 means Injector Fault and Side Stand Switch fault (2 different sequences = 2 different issues happening) , just an example!
The seat has a BLACK SHROUD with 2 plugs 4-pin and 2 pin
You have connected something to the 2-pin plug what is it ? It should be empty
The black-shroud hiding those 4pin & 2pin plugs is for diagnostics only.
