Jul 18, 2025 at 7:06 PM
#20075
Also , just to be extra sure, when the stator cover is removed , get a big 17mm or 19mm socket , and turn the flywheel anti-clockwise, slowly, this will make sure the engine is not jammed (maybe bent valve or bad timings due to cam chain error , tensioner error or valve hitting piston due to wrong timing)
