Viewing 3 reply threads
    • #20054
      Jono
      Hey guys
      Just got my hands on a 2001 gt250r wasn’t used for 5+years I got the motor running but once I put a new battery and new chain+sprockets when I hit the start button nothing happens apart from a click coming from the starter solenoid
      Any help would be great thanks
    • #20074
      Drain oil (just incase it is hydrolocked with fuel) (Sometimes there is fuel in the oil because the carbs have jammed open and is sending fuel in to pistons even if bike is off.
      When the oil is drained, remove the stator cover ==> Look behind and see if there is damage to the flywheel-sprocket.
      Also spin the Flywheel-Sprocket , it must spin ONE-WAY , and FREEZE if you spin the other way (it is a One-Way hub) , if it spins both ways or refuses to spin in any direction,m you may have a damaged “starter clutch” which is that one-way hub sitting behind the flywheel.
      It is a early 2000s GTR , so it is best to check behind the flywheel.
      Also , remove the stater motor , remove the battery.
      Connect + terminal to starter motor wire.
      Then connect (negative – minus) to starter body , be safe as sparks will come out! –> does it spin healthy ? – This is you checking starter motor is good too.
      You may possibly needed to replace the starter-solenoid as your final puzzle . DO this after checking all the above ^^^ first.
      • #20084
        Jono
        How difficult is removing the starter motor?
    • #20075
      Also , just to be extra sure, when the stator cover is removed , get a big 17mm or 19mm socket , and turn the flywheel anti-clockwise, slowly, this will make sure the engine is not jammed (maybe bent valve or bad timings due to cam chain error , tensioner error or valve hitting piston due to wrong timing)
    • #20093
      Starter motor is held by 2 bolts on its body near the cable. And just carefully pull it out because it has an O-Ring seal near the spinning teeth
      Drain oil 1st.
