Jul 17, 2025 at 9:57 PM
#20053
Sensor fitted, Â got it setup as per instructions on here (has the “c” with the “-” above it, and not just “c” on its own). Â It now idles at around 3-4K and then drops, but then dies.
ISCV seems ok when bench tested. Â So I’m thinking I need to double check the SAV, pipes and also the Lambda sensor (as the loom and sensor were both missing the plug so I have fitted one, but perhaps miss wired). Â No error codes.
Getting closer but not quite there. Â Funny though that last year it was running on the drive for ages.
