Forums π₯ PiT STOP π§ Hyosung Technical Help Valve clearance, camshaft, camshaft tensioner β a problem or a serious fault? Reply To: Valve clearance, camshaft, camshaft tensioner β a problem or a serious fault?
Hello, since I decided to replace the timing chains right away and, while I was at it, the already dismantled cylinders, I stopped at the stage of removing the magneto⦠Do I need a special puller for it? I have a puller in my workshop, but it is too small to fit the magneto. Are there any other ways to remove it?
I checked the serial number of the tools from the service manual, but I donβt need them for that amount of money, as I will only use them once. (hopefully π )
Try M30 x 1.5 puller from Amazon, it pulls rotors of different 125 motocross bikes.
