Jul 13, 2025 at 10:26 AM
#20013
Is there anyone local in Ireland who is breaking a GD250 NAKED , so you can get its top yoke and risers ? It will be easier getting a naked version.
Sorry if the Add Media button was confusing, did it come up with an error or ? Or is it too clunky for phone use. I will take any feedback to design it myself (i am 100% going to renovate the site later in the year so its more simplistic to navigate around)
Regards
If you must use your current setup , remove the clip ons and be warned:
- You may need longer brake hose
- longer clutch cable & throttle cable possibly
- Find a local breaker and get “2005-2016” GV125/GV250 risers that fit 22mm bars (MUST be this specific year range)
- Drill 1 hole each side, you may run in to trouble , so do it very cautiously or pray we can find a spare yoke to test things. (GD or GDR)
GVs use one bolt risers per side and are much higher than chinesium ones. It is the top yoke we have to worry about giving us a small flat section to sit them on.
