whipflash191
  • Topics: 3
  • Country: Australia
  • Bike Model: 2010 GV650 EFI
It is in fact a daewoo ECU annnnd apparently it awful condition. If i’ve followed the diagram right i think the broken pin is D3 for the brake lights (which don’t work so that would make sense). I’m sure this is done for but im going to try and clean the connector and pins anyway and see where I get. Couldnt get worse at this point could it?
EDIT: I was infact reading the wrong wiring diagram for the GT not the GV. This pin should go to the starter relay, clutch switch and ‘filter’. Bike cranks though, a previous owner has spliced 12v into the harness and I’m guessing it was to bypass this and get the starter relay going.
View post on imgur.com
