LaserBeam
Electrolysis works really well for rust removal. For sure check out some videos of the process on YouTube, it will make it easier to understand. Once finished, tip out the solution & rinse the tank out with a bit of unleaded or diesel. Slosh that around so it COATS the ENTIRE INSIDE with fuel & tip it upside down and slosh it around as you pour it out again. This will coat the walls & prevent it from insta-rusting … think they call it flash rust, where the newly cleaned metal starts to oxidise instantly. The oil in the diesel or unleaded will coat the metal and protect it a bit. Can rinse tank with distilled water then rinse with fuel. Should be ok to just rinse it with fuel a couple of times.
