Have a look at this too:
How to change / upgrade fuel lines & fuel filter on CARBY GV125 & GV250 Diagram
Also , if the carbs came out, maybe it is possible the intake o-rings need replacing ?
Look at this below:
[Guide] Intake boot manifold removal GV125C / GV250 Carby (Air Box Tutorial)
if the o-rings under those pipes don’t sit right, you will get all you just described.
If not,  triple check the floats were not accidently bent even just 1mm error , may mean too much fuel or too little fuel
See here , and scroll to where it says check float height in that topic
GT125 2003 Performance Issues
GT/GV= Same engine, same carbs.
