Apr 7, 2025 at 5:11 PM
#19251
Right done this There not fluid coming out from front brake is that normal?
Loosen the lower screw on the front brake and then try to Press the rear brake to see if the fluid will come out. Do it coupe of Times, if the fluid starts to go, tighten the bolt, pump the brake, hold it and loosen the screw, the tighten. Then te same for the rear brake (check rear fluid level and top off when needed).
