Chris
  • Topics: 8
Clutch switch. side stand switch. right switch gear. ecu connector plug. these were our issue on a customer 2017 GV i had to fix. no fi errors. But i suspect sparking coils + caps if ecu primes the pump
clutch switch is new, side stand switch removed, right switch seems to work (cuts pump of if flicked), cleaned ecu plug.  Might have another coil somewhere.  Just wouldn’t have thought they would both go at the same time.
