Hopefully looking for someone to rebuild my carbs and sync them for me
If you would like , send us a message via email ? If distance is an issue for the bike transport, we collect and drop off but… you can also just simply post the carbs to us on their own.
Can you at least be 100% certain, the engine is compressing 150 psi each on each cylinder after its warmed up?
Take plugs out (both of them)
Full throttle
Crank bike for 5 seconds
Tell us compression for each cylinder, a mech can do it easy just by lifting tank off only and removing rear plugs and the front can be done when the oil cooler is lowered from its mounting. No need to remove carbs or airbox
I have personally had to fix and sync up a whole carb for someone but he had to rebuild the engine due to low cylinder on the rear as the bike was being difficult to start sometimes and would occassionally run weak on the road , then lose a cylinder eventually.
