Viewing 5 reply threads
    • #19056
      Barry O’Neill
      Hopefully looking for someone to rebuild my carbs and sync them for me
    • #19058
      If you would like , send us a message via email  ?  If distance is an issue for the bike transport, we collect and drop off but… you can also just simply post the carbs to us on their own.
      Can you at least be 100% certain, the engine is compressing 150 psi each on each cylinder after its warmed up?
      Take plugs out (both of them)
      Full throttle
      Crank bike for 5 seconds
      Tell us compression for each cylinder, a mech can do it easy just by lifting tank off only and removing rear plugs  and the front can be done when the oil cooler is lowered from its mounting. No need to remove carbs or airbox
      I have personally had to fix and sync up a whole carb for someone but he had to rebuild the engine due to low cylinder on the rear as the bike was being difficult to start sometimes and would occassionally run weak on the road ,  then lose a cylinder eventually.
    • #19061
      Barry O’Neill
      Sorry mate, sick of giving”mechanics” money for nothing. Have no idea of psi. Bike worked fine until one of said “mechanics” totally screwed my carbs up. Can you quote me pickup/drop off (Ashford Kent) and sort my bike out please
      Much appreciated
      Barry
    • #19066
      Sorry mate, sick of giving”mechanics” money for nothing. Have no idea of psi. Bike worked fine until one of said “mechanics” totally screwed my carbs up. Can you quote me pickup/drop off (Ashford Kent) and sort my bike out please Much appreciated Barry
      The bike is going nowhere UNTIL it is fixed, we’re different.  We even have a spare carb on the shelf in immaculate condition as a “test bunny” to prove if its the engine that needs attention rather than a carb. Sorry for the delay today, we had to collect a bike today!
      Please click “Contact” below to discuss what we can do with yours ?
      Contact
      I will be awaiting your email 👍
    • #19067
      Barry O’Neill
      Can’t get through on email. Tried other means but not available
    • #19069
      We will find you now.  Check your FB messenger.
  • The topic ‘Carb rebuild and syncing 2016 gv125 c’ is closed to new replies.
