ā™ ļø M77
šŸ‘‘ Admin
why dont they like wheelies seen people do it before , does it put oil in wrong places or something ?
– Forks not made for wheelies , it barely holds the 180kg bike without bursting oil seals.
– Engine does NOT like to run dry when oil suddenly sloshses away from the spinning parts that need constant lubrication (cam chains, tensioner, clutch basket , bearings (again bearings!!!)
– There is no other 125cc you can find that has a lot of bearings inside than the Hyosung does, they must stay soaked in oil all times.
– Oil Pump doesn’t like to push itself too hard, it’s small but enough to flow aroundĀ  ,Ā  Ā when the engine is hot the oil pressure drops toĀ  0.5 megapascalsĀ  Ā ( i have my own donors fitted with pressure gauges so i know when its low or high) ,Ā  0.5 is when it’s idling hot but can wane/hover around 0.3-0.6Ā  , you wouldn’t want to drop a clutch and wheelie off when it’s that low.Ā  Ā It’s normal 0.5 as the bike is idling , it will pick up when the rider gets in gear and rides nicely.
– Top heavy girl,Ā  i’d rather do it on an SM bike.
The guys that wheelie 125r’sĀ  are not friends you want when things go wrong for you.Ā  They don’t care šŸ˜‰
