Viewing 7 reply threads
    • #18785
      Anonymous
      Inactive
      anyone know if there is a engine guard/stunt cradle available for the GT125R or has anyone made one quite capable of welding just wondering where best to mount it because of the fairings
      cheers all
    • #18790
      For what reason would it need one ?   It seems the fairings already shield the engine  (not perfect but still plastic!)
      Also R&G UK already make large crash protectors that go through the fairing incase the bike drops on its side.
      There isn’t an “off the shelf” pre-made cradle / engine guard for the GT125R
    • #18791
      Anonymous
      Inactive
      i want to protect it from smashing the panels ive seen the protectors but wasnt sure if they will protect all damage if dropped
    • #18792
      That’s a fair point there! – Not seen such pre-made cages you speak of, so it looks like a custom job  if you’re not keen on the simplistic R&G Crash Mushrooms they sell.
    • #18793
      Anonymous
      Inactive
      they look ok dont get me wrong but im worried if i ever dropped it there would still be damage may have to do lots of measuring up, plan on trying to wheelie it at some point anyway just cause i can lol
    • #18802
      Please please don’t wheelie it! , you WILL regret it.   Even the SV650’s don’t like wheelies either.
      A DRZ400 SM? yeah sure go ahead!
    • #18803
      Anonymous
      Inactive
      why dont they like wheelies seen people do it before , does it put oil in wrong places or something ?
    • #18809
      – Forks not made for wheelies , it barely holds the 180kg bike without bursting oil seals.
      – Engine does NOT like to run dry when oil suddenly sloshses away from the spinning parts that need constant lubrication (cam chains, tensioner, clutch basket , bearings (again bearings!!!)
      – There is no other 125cc you can find that has a lot of bearings inside than the Hyosung does, they must stay soaked in oil all times.
      – Oil Pump doesn’t like to push itself too hard, it’s small but enough to flow around  ,   when the engine is hot the oil pressure drops to  0.5 megapascals   ( i have my own donors fitted with pressure gauges so i know when its low or high) ,  0.5 is when it’s idling hot but can wane/hover around 0.3-0.6  , you wouldn’t want to drop a clutch and wheelie off when it’s that low.   It’s normal 0.5 as the bike is idling , it will pick up when the rider gets in gear and rides nicely.
      – Top heavy girl,  i’d rather do it on an SM bike.
      The guys that wheelie 125r’s  are not friends you want when things go wrong for you.  They don’t care 😉
