Yes I am able to turn the rotor both ways
Go behind the Flywheel Drum  = See the BIG sprocket with lots of teeth?
Remove your starter motor first.
Can you spin that big sprocket in both directions ?
It could be important, as Simon is likely to suggest your sprag clutch & starter motor need fixing or replacing
This is the sprag clutch that starts your bike  (also known as One-Way Starting Assy)
