Viewing 4 reply threads
    • #18686
      Fallenst4r
      Hello everyone, was wondering if I could possibly receive some help and advice.
      i bought a 2015 hyosung gt650r I don’t know much about bikes but it has spark the starter spins which spins the flywheel which should turn the bike over but it doesn’t the only thing that happens is both starter and flywheel spin and that’s it any help would be appreciated thank you
    • #18713
      Simon
      It sounds a bit strange it could be the starter clutch or the key has sheared need to remove the stator cover for further investigation
      • #18714
        Fallenst4r
        Yes I’ve begun to suspect it is the starter clutch assembly as I am able to spin the rotor both ways, the rotor should only be able to spin one way right?
    • #18715
      Simon
      Can you turn the engine by hand
    • #18744
      Fallenst4r
      Yes I am able to turn the rotor both ways
    • #18757
      Go behind the Flywheel Drum  = See the BIG sprocket with lots of teeth?
      Remove your starter motor first.
      Can you spin that big sprocket in both directions ?
      It could be important, as Simon is likely to suggest your sprag clutch & starter motor need fixing or replacing
      This is the sprag clutch that starts your bike  (also known as One-Way Starting Assy)
