Jan 1, 2025 at 3:10 PM
#18279
Push the master cylinder further AWAY from the throttle switch gear.
Ie…. [top yoke]____[cylinder]___[switch gear]
Then push it away from the switch like so…
[top yoke][cylinder]___[switch gear]
Once done, rotate the cylinder FORWARD towards the front tyre , but leave clearance by about 1mm margin, so it will be tight..but hopefully this should help.
The only leaver that requires no messing around is Korea’s approved XRT Levers (XRT is based in Korea & are the “official” accessories maker for the GT bikes) but costly though!
