Hey all! First off Happy new year!
Ever since I got this 650 it’s had these aftermarket brake lever that hits the plastic. It hits hard enough to actually apply the brakes at full lock making it hard to roll around and it’s now unfortunately scratched the plastic.
I’ve rotated it as far down as it will go but now the reservoir hits the top triple clamp and still hits the plastic but not as bad
The clutch lever would also hit but I’ve managed to rotate that to a position it cant
I’ve read somewhere that Hyosung used different levers or something after a certain year? And I had a quick look on eBay all the levers I can find list 650 only up to 2009 not 2010 onwards. Coincidence?
Do I have a different master cylinder that requires a different style brake lever to not hit? (It’s the “adjustable” part that hits, the bit that the spring is under, you can see it poking out near the pivot point)
Thissss was close to just dropping a bunch of cash on a new master with remote resivoir, domino quick throttle and an easy pull clutch lever with new slim switch blocks to match just to solve this one minor issue and give it a birthday
