Oct 17, 2024 at 6:54 PM
#15224
335 crank sensor (probably wrong stator)
113 Intake Air Temperature Sensor (likely at fault)
562 battery (recharge it or its too old) (EFI is a hungry machine)
Use the service manuals in this forum for EFI, to help you fix these error codes by testing them as the manual shows you how. or replace said gadgets
Sometimes, the harness needs all plugs disconnected and cleaned out with contact cleaner and dry it 24hrs before fitting parts (as wet liquids & electrics don’t mix!)
ACF50 will be the next bottle to use to stop connector plugs rotting in bad weather
