Sorry ,
I meant the Engine from the GV itself was running wasn’t it ?  =  leave it in the GT frame.
Just focus on getting a CDI unit for the GT bike.    GT harness & GT CDi will run a GV engine.
As long as the GV was a carb motor.   If the GV was  EFI  (2008 onwards), then you would need to take the carb flywheel and carb stator in to the GV engine to make it run.
Long short =  Leave your setup as it is,  just swap the CDI  back to a GT one.
Then check for sparks.
A GV harness & GV CDI will be complicated to run on a GT frame. (different electronics including the dash!)
