madbikeruk
  • Topics: 2
Marcel is the expert with these bikes 😁 I’m just a good spanner monkey
I done a engine swap on my bike gsxr 750 carb to 1L injection so know a bit about it 🤔
You will need the ECU for the engine to match , if you have the wire loom from the new engine it helps set things up if not you might find it easier to make a loom and add in all the bits on the bike lights etc to it or you can have it run as 2 systems the original wires for lights etc and the ECU just do the engine.
If you think of it as the main bit is the engine work the electrics back from there as the rest is mostly just swinging things on and off, so not that hard to rewire
I don’t know that bike,  so wait to see what Marcel says he’s the pro 😁
