Sep 28, 2024 at 10:29 PM
#14986
Okay,
Try this =
- confirm 12v is at the fuse box
- confirm 12v is at the ignition wires (green plug under airbox)
Can you turn the key on , and do you see anything at all on the dashboard not even so much as a light ?
Is the engine still running (ie, the bike still starts when turning the key on ?
last thing , is this a carb model or EFI ?
If it is EFI , what ECU does it have ? (Delphi, Mitsubishi Japan, Daewoo, etc)
