    • #14976
      Zac
      Hey guys, when I was riding home the other day my speedo, turn signals horn and brake light suddenly stopped working. I’ve checked the fuses and a little of the wiring and cannot find anything out of the ordinary. Any help would be appreciated Thanks.
    • #14986
      Okay,
      Try this =
      • confirm 12v is at the fuse box
      • confirm 12v is at the ignition wires (green plug under airbox)
      Can you turn the key on , and do you see anything at all on the dashboard not even so much as a light ?
      Is the engine still running  (ie, the bike still starts when turning the key on ?
      last thing , is this a carb model or EFI ?
      If it is EFI , what ECU does it have ?  (Delphi, Mitsubishi Japan, Daewoo, etc)
