I bought a new sender from a car/truck ; although the mount flange is the same pattern and float arm would need to be modified it works bassakwards as far as resistance goes. Which is what I feared would happen as most cars/trucks level senders are mounted from the top of the tank unlike , I assume most bikes.
I would go with an old-school manual Petcock if the location was reachable. I don’t remember from whom I purchased the thing or what model it fit.
I was probably shopping while drinking and didn’t go from your list of recommendations. Also while drinking : The”SWAP THE WIRES “comment of mine , WHAT AN IDIOT. I’ve got a sender that I bought accidentally with the oval base which I guess is supposed to fit the injected models if someone wants it, just pay for shipping ( I’m in the US) the readings on that are 8.6 ohms empty 97.2 ohms full so this may not be in order either.
Lest I word on more; I think I’ll just seal the broken sender back in the tank and move on to other issues. Thank you for your help.
