Sep 12, 2024 at 11:29 PM
#14775
When you connect the multi meter to the indicator wire= You may say 12v 0 12v 0 12v 0v in quick succession if its working , but do you get any βpulsingβ voltages at all ? The harness of the bike must be the one to actually send power down the lines in the first place before the bulb flashes ? If the REAR LEFT & REAR RIGHT are working = Relay is OK. Sounds stupid, but be wise , connect 2 scrap wires from the shed to the battery and connect it to your indicator itself ? If it flashes , it was the harness likely having a break somewhere or a kink or a rusted patch if water went under the airbox
appreciate the advice will pick up a multimeter tomorrow and check it out π
