Sep 11, 2024 at 1:45 PM
#14749
That’s just odd , if the ECU was dead the dash would show a steady FI light with the dash saying “CHE” on the LCD glass (or if the user has pressed the kill switch button towards the front tyre)
Red FI light on Delphi ECU’s disappear after the bike runs (provided there is no errors while running)
You said 2 plug ecu , so i am assuming it is a Delphi one. Daewoo ECU’s don’t really store information, so procedure might be a little different.
Though , you could try to buy a spare working dash locally where you live , just make sure the donor bike had the same ECU as you did. (Or even buy a spare harness!)
