Relay yes
Also check the connectors for anything suspicious at the relay zone and the connectors for the lights incase of signs of burns
Check fuse box , must be 15A
Check the right and left handlebar switch gears , (open them) look for bad contacts  (you said it was sat for years) , so we’re checking for signs of damaged contacts and also check the connectors for the switches going in to the harness  (for rotting pins) and use “Contact Cleaner” on the entire bike to be sure the harness isn’t getting shorted and all signals are passing through.   Sometimes it helps to remove the harness and re-wrap it with an extra layer of waterproofing tape as the hyosungs don’t like the rain as much as humans do but they will cope with wet weather though like any, it is just their weakness.
