Last thing i wanted to ask before i forgot , when the dash is plugged in.   (never mind the ECU) , do all the icons flash below:
  • Left & Right Turn Signals
  • Hazard switch on right switch
  • Neutral Light On
Confirms if the circuit board is at least feeding power to the top icons , and then if the ECU does arrive , the red FI light should come on.
However, even with the OLD ECU, the red “Fi” light should be red as soon as the key turns on, is that true ?
