Alukewarmpuddle
  • Topics: 8
I just gave the bike a cold start with the choke on. It’ll idle high then settle but after 10-15 seconds the idle will slow then the engine will cut out as if it’s running out of fuel. Is there anything I should check on the carbs that could be causing this? It runs perfectly without the choke in all gears at WOT so I’m guessing something is messing with the choke/enrichening circuit?
