Update: Realised I don’t need to take stator off and a simple test using a multimeter should indicate if she’s good. I found a picture from marcel I believe from another topic describing how to test it and after following the steps, my readings on all three pins were 0.3 (see picture below). Also watched a youtube tutorial and put the negative pole of multimeter to negative part of battery and the positive pole of multimeter to each of the three wires and my multimeter stayed on OL which I believe means there’s no short? Judging by these tests, the stator is good right? I can’t do a dynamic test because bike doesn’t run and i’m not sure if 0.3 is the number it should be at (guy on youtube was getting 0.4 so i think i’m okay). Anyways, let me know!
Thanks!!
