Jonathan
Okay, I was working on cosmetic issues today and figured id make a checklist on the issues with the bike while we wait for the ECU.
Headlight fuse has no power to it
Tail light only turns on if i manually put power to the relay. Brake light works regardless
Dash LCD screen doesnt work
High beam light doesnt light up on dash
Spark plugs no spark (brand new spark plugs and ignition coil leads)
Fuel pump not priming (working when i put power to relay)
Im pretty sure these are all the issues. Im sure im not gonna plug a new ECU in and its going to fix everything I just listed… right?
