madbikeruk
  • Topics: 2
If compression is good have a look at intake manifold see if it’s split it’s common and it messes with the fueling , unless you have changed something in the carb or done some big performance parts it’s shouldn’t be to far off
idle screw and mix screw  need adjusting if everything else checks out
