Viewing 2 reply threads
    • #14569
      Amit noble
      Could someone help me tune up the carb and get my bike running smoothly? I have a 2008 gv125. First project with a carburetor.
      Already rebuilt it got the bike running. Just need the finishing touches to make it idle smoothly (doesn’t run at all without the choke) and run at peak power.
      thank you in advance
    • #14579
      Can you get hold of a compression tester ?
      Warm up the bike even with choke for 10mins max
      Then remove spark plugs on both engines
      Put compression tester on front engine spark plug hole => Press start to crank bike for 5 seconds maximum
      Record the PSi reading from the gauge
      And repeat this for the rear engine
      Tell us the engine compression on both cylinders , i feel like it is best to start here first.
      If the engine is compressing well above OEM specs , then it is easier to diagnose the carb next
      if not , copy these instructions and have your mechanic visit your bike to do it first,  and update us the results.
    • #14668
      madbikeruk
      If compression is good have a look at intake manifold see if it’s split it’s common and it messes with the fueling , unless you have changed something in the carb or done some big performance parts it’s shouldn’t be to far off
      idle screw and mix screw  need adjusting if everything else checks out
