Sep 3, 2024 at 6:19 PM
#14656
10-1-3-2 translates to C132
This error code says = Front Cylinder Oxygen Sensor Circuit High Voltage
Copied from service manual
After engine running, the oxygen sensor signal is inputted in ECU
since then 300 sec.
In this case, the sensor voltage should be the following.
Sensor output voltage 䥰 1.0 V
Without the above range for 29.4 sec. and more, 0132 is indicated
Fault = Oxygen sensor unit, and or lead wire / coupler connection
