Viewing 12 reply threads
    • #14646
      Endru
      Witam posiadam 250gt chyba 2011 .Jak sprawdzić błedy bo tylko kontrolka miga F1 i nie mam jak odczytać kodów .ECU delfi
    • #14647
      Endru
      Hello, I have a 250gt, probably 2011. How can I check the errors because only the F1 light is flashing and I can’t read the codes. ECU delfi
      <hr />
    • #14650
      Turn the key on and off 3 times and dash will display the error
      or go to “Technical Section => Manuals ” and download the 250 service manual on this forum and let us know what code it says.
    • #14653
      Endru
      Hello, the F1 light blinks 10 times, break 1, break 3, break 2, and so on cyclically, is it c 13? I downloaded the instructions only for my type, there are none, only Regards
    • #14656
      10-1-3-2 translates to C132
      This error code says = Front Cylinder Oxygen Sensor Circuit High Voltage
      Copied from service manual
      After engine running, the oxygen sensor signal is inputted in ECU
      since then 300 sec.
      In this case, the sensor voltage should be the following.
      Sensor output voltage 䥰 1.0 V
      Without the above range for 29.4 sec. and more, 0132 is indicated
      Fault = Oxygen sensor unit, and or lead wire / coupler connection
    • #14657
      Endru
      So c22 from the manual I downloaded. Thanks a lot for your help and I’ll get back to you when it comes out. And I have two questions; is cylinder 1 counted from the front wheel? Is it possible to copy the manual from which you gave the answer to my question?
    • #14660
      The “italics”  are the words i copied from the service manual , it is usually the same error on the GT650 and GV650 because they used the same O2 Oxygen Sensor as the GT250 model.    No.1 Cylinder is the pipe at the front tyre yes  (here in UK we translate this as Front Engine Exhaust Manifold Header)
    • #14661
      Endru
      Hello, one probe is about 1 volt and the other 0.7 volt and sometimes jumps to 0.5 volts. In your opinion, should I replace them because they write differently about these voltages?
    • #14672
      It is not a bad idea to replace them! – We have some used ones on ebay if you need them (click here) or check with your local dealer if you want.
    • #14681
      Endru
      Hello Marcel Could you give me your email? Something is not working on eBay. If there was a way to deposit money directly into a bank account.
    • #14688
      Sure, contact me directly below here
      Contact
    • #14981
      Endru
      Hello. the sensor (o2) arrived, thank you very much. But unfortunately the same error pops up. I even replaced the sensors from 1 to 2 and vice versa, the same error pops up. Now replace the ECU? Because I have no idea. The same error is often seen on the forums. Is it a factory defect?
    • #14985
      I would remove the ECU, and use compressed air to clean the pins carefully and every connector on the bike.
      You can use “contact cleaner” on all plugs of all sensors, it can help solve resistance issues with the ECU
      Also do not use contact cleaner on ECU, as liquids may leak into the ECU, which is a rare part for your 2011 model!
      If problems keep happening, try replacing the ECU  or  maybe go get a replacement harness.
      If not,  try to find a 2015 harness  & 2015 ECU from ebay USA as those bikes are very common in USA , they use DELPHI ECU which is better.
