Side Stand switch bypass = Get electrical tape ,  cut the wires under the kickstand going to the stand switch ==> now join the 2 wires from the harness going up to the front tyre , and use lots of tape to waterproof it and avoid any arc’s or electric sparks/shorts.
Side stand is bypassed.
Let us know if it worked.
Clutch switch =  Plug will be under the airbox near the left side of the frame ,  find a similar bike that uses the same clutch switch as hyosung ,  even an old Honda machine , or go to bike garage with your old switch , ask them to order you a similar switch for the clutch lever.
If you remove the clutch switch, check wires for rust and use contact cleaner product (it may be called a different name in your country)
